festus_mcBitcoin
- Festus
- Feb 1, 2021
- Las Vegas
- 2015 911 Turbo S, 2021 TTS (June 11)
- #1
Future Taycan Turbo S owner, delivery date June 4, 2021.
I live in a high-rise so I can't install a dedicated charger in my home. Instead, I plan to use the DC fast charger at the neighborhood mall across the street, like maybe once a week. My thought is that if in fact the fast charger will get me to 80% in twenty-three minutes, I can simply leave it plugged in while I grab lunch at the mall.
I read elsewhere that consistently using a fast charger instead of the slow trickle chargers you see at these ubiquitous ChargePoint locations is hard on the battery. Is that the case? How negative are the effects? This is a three year lease so if the battery degradation doesn't show up for a period that exceeds three years, then no problem. I'm guessing since this model is only a year old, there's insufficient data to make a judgement one way or the other. But anecdotally, are any of you guys using fast charge routinely, and if so, have you seen notable degradation in battery life?
Another claim that keeps popping up is that the '12V battery is dead' bug is associated exclusively with the slower 'Level 2' chargers and, for that reason, using fast chargers would make me less vulnerable that particular bug. Not sure if that's true or not but figured it was worth mentioning.
Thanks!
Thanks!
