Forgot to clarify - this is in Normal mode. I don’t drive like a Prius driver but I don’t race every Tesla fella with a chip on his shoulder either .Awesome!!!!!!!
Can you share your consumption figures miles / kWh from your Total Trip reading?Forgot to clarify - this is in Normal mode. I don’t drive like a Prius driver but I don’t race every Tesla fella with a chip on his shoulder either .
Where do I get that?Can you share your consumption figures miles / kWh from your Total Trip reading?
https://my.porsche.com/core/de/de_DE/vehicles/Where do I get that?
Either from the car - right tube (select and roll through the options to display trip then press to select what trip data or PCM screen - or from My Porsche where all trip data is stored / accessible. Easiest from My Porsche. Only the Total Trip is of interest.Where do I get that?
You should still be able to see either from the car (PCM / right tube as I've just described above) or the web / mobile app - not dependent on talking to the car. Tap the picture of your car and then scroll down to trip data.Here is my current guessometer reading.
It's about average for my car in summer, but doing lots of short journeys.
I can't show the current 'total figures' as the car isn't talking via the app for the last couple of days. Sure there was a thread about that recently? - can anyone point me to it please
Disconnect 12v battery or pull the PCM fuse to reboot properly.Here is my current guessometer reading.
I can get that, but the info hasn't updated since 14th June - although car used daily and all seems OK in the car - but Porsche can't seem to ping the car - hence both apps and Web based info are not up to date.You should still be able to see either from the car (PCM / right tube as I've just described above) or the web / mobile app - not dependent on talking to the car. Tap the picture of your car and then scroll down to trip data.
It needs a hard reset - others on the forum took the advice recently and all their troubles (including connectivity) went away. Neither the app or privacy are the root cause.I can get that, but the info hasn't updated since 14th June - although car used daily and all seems OK in the car - but Porsche can't seem to ping the car - hence both apps and Web based info are not up to date.
Tried resetting using privacy on/off in the car and reinstalling app - still no change through online routes since 14/06.
May try fuse option (below) if it doesn't 'self right' soon.
Sorry for hijacking thr thread.
Mine's fine (so far) - all weekend and today. For days the app 'connected' icon has never shown as connected so I ignore as the data and functions are working.Pretty sure Porsche's toaster is down. Also no updates since saturday, and I've driven the car for a bit. It's at a workshop for a doording and can't track it to see if it's being worked on.
I don't have the PVTS+ option activated on my car W1NGE.It needs a hard reset - others on the forum took the advice recently and all their troubles (including connectivity) went away. Neither the app or privacy are the root cause.
Is your PVTS+ working - Vodafone (not Porsche) service - if not sure phone the SOC and they'll tell you if and when it last checked in?
I'm guessing you've tried the 2nd key fob trick too with a different Porsche Connect ID?
If your OTA module has been checked out then a hardware failure is not to blame either.
No worries.I don't have the PVTS+ option activated on my car W1NGE.
I just tried the 2nd keyfob. No change.
I assume the data side in the car (Vodafone) is ok, as I am getting the LTE symbol in the car and I listen to Internet radio all the time.
Everything is fine in the car.
It just seems that accessing the car info remotely - via the apps isn't possible since 14th June.
Sorry all for hijacking the thread once again!
