Dave T
- Jan 14, 2020
- Boston
- 2020 Taycan Turbo
Did that hanger-upper thingy you have the end of your charger hooked into - come with the PMCC? I didn't get one of those.Porsche changed the cable length to ~1 ft. With a revision. Good luck finding the long one (which radiated a lot of heat because the #10 gauge wire is too small).
If handy with electrical connections, turn off the breaker and rotate the receptacle (socket) so the ground pin is at the bottom. This will allow the Charger to be higher, the opposite of my installation:
