- Aug 14, 2021
- Ohio
- 2022 Taycan 4S
The Pcarwhisper video posted above is good showing the steps to use the MyPorsche app to charge at EA stations.
Note that when he got to the station, he used the app and hit the "start charging" button on the app, then connected the cable to the car. Usually the EA station console says "Plug in first". Don't plug in first if you use the MyPorsche app. Start charging with the app, then plug in, like the video shows.
After the charging process is successfully stopped, the Taycan will turn on a light above the charging plug which shines down on the plug, indicating you may remove the plug. This light is separate from the light on the button, which can change colors.
