Daniel
- Mar 26, 2021
- Europe
- 2021 Taycan 4 CT
Found in this forum:Fast charging does degrade the battery, that is a fact. There is a rumored spare capacity in the Taycan batteries (it charges to lower SoC at first, will try to confirm one Porsche manages to build and deliver one for me). Why would they let you? Because you need it on long distance trips. Does it degrade the battery faster? Sure it does, as does using launch control mode. Does Porsche still warranty the battery even if you charge at 250KW and lanuch every day? Of course they do, but notice that they don't guarantee 100% of the original capacity. I have not found the actual percentage, but Tesla for example only warranties 70% of original capacity in 8 year or 100K miles. So if a 400 mile range Tesla degrade 280miles, it's still not covered under warranty (279 qualifies you for warranty coverage). I suspect Taycan is the same.
11KW is not fast charging. Minimum DC charging is 50KW, and the charging rate which starts to do damage is usually considered 1C (i.e. rate which would charge the battery in 1hr), so for a Taycan, ~97KW. As a side note, I've been charging one of my Model S at 80A and another at 48A for years, minimal degradation.
That is my plan once the Taycan gets here (current TYD estimate February 2023). For trips I plan to do 98% since that keeps regen enabled, unless it's winter then 100% on trips since regen is limited by low temps of the battery anyways.
