satchurator
- Mar 22, 2021
- Massachussets, USA
- MY22 CT4
Thanks to everybody weighing in on this portion of the thread. Appreciate the tips on extension cables, GFCI and managing the current draw from within the PMC+.I would be hard pressed to see how anything like this cord presents any serious risk…I’d recommend paying the extra $7 for the “lighted” version - which has a small LED light in the plug ends so you can “see” that the cord is powered…
this is 12 gauge wire, 3 conductors (hot, neutral, ground) and rated for full 15 amps - and the PMC+ with the proper supply cable attached (NEMA 5-15 supply cable) will pull the recommended 12 amps - make sure the plugs are well seated and keep the plugs out of the wet and I’d be mostly nearly completely un-concerned - check in on it periodically during the first few hours and make sure it isn’t getting too warm and nothing is melting at the plug ends and it should be fine.
There is a 14-50 socket in the home, but the distance from that to the spot where I can park is just too far to justify a 14-50 extension cable.
